Solved: Multi-Rebar Annotation
Hi guys,
We are released our Package to Dynamo Server.
Content:
• Rebar:
  • Retrieve all rebars in host
  • Retrieve Rebar Normal and True/False
    • Annotation:
  • Multi-Rebar Annotation
  • Create Dimension From ReferenceArray
    • Selection:
  • Pick Point
  • Select Duct, Pipe, Floor, Windo, Door, Rebar…by select rectangular region
How to use: https://bit.ly/2WlhJGN
Group Facebook: https://www.facebook.com/groups/263033924832758/
We would be pleased to hear from you!!!
Many thanks!
Hi! There’s a problem with ACO Package when downloading directly through Dynamo. All versions from 1.0.0 to 1.0.4 look almost empty. There are no files in “dyf” folder. Could You please check it and release a proper version of the package? Looking forward to check your solution.
@hungthp.com @TomaszGorecki
The ACOPackage dyn folder is empty.
Have you managed to solve this problem?
Thx guys
What version dynamo you use ?
Have you downloaded the correct version yet ?
Or you can download package at https://dynamopackages.com/ and copy to path package
That worked perfectly, looks like I was downloading the wrong one (ACO).
Thank’s mate
Hello! I tested this node (Annotation.MultiRebarAnnotation), and find out it doesn’t work for several rebars:( Could you upgrade this node with pacage?
Also (unfortunately) it doesn’t work for RebarInSystem :pensive:
@maksin Do you have any idea how to deal with it?
I have no idea how I should deal with it in dynamo. Answer in Revit API
