Hi, is there any way to create multi rebar annotation tags using dynamo?
Hi, I don’t know if it’s possible, could you also send your first attempts so that someone can give the appropriate advice?
Hi Yna, I didn’t found any node than allow to create multi rebar annontation in revit
Did you also try the Archi-lab node Create Annotation Tag?
https://forum.dynamobim.com/t/tag-textnote-multi-category-elements/9592
Hi Yna, I am uploading rvt and dyn files.
I tried but the archi-lab node doesn’t access rebar.
Test Create Multi Rebar Annotation Tag.dyn (18.1 KB)
Test - Rebar detailing.rvt (932 KB)
