Create "Add an Aligned Multi-Rebar Annotation" by Dynamo
I’m looking for a way to use a dynamo to indicate bars in a set, such as reinforcing walls or ceilings. Marking single bars I have just got caught up on dynamo 1.3 but do not know if you can get a dimension line and multi rebar annotation?
You need to create a pyton script with this method : https://apidocs.co/apps/revit/2016/b3646880-ef76-d0d4-68d9-2c976163c340.htm
Solved: Multi-Rebar Annotation
