Solid extrusion from rhino geometry
Hi, i’m trying to define a solid on the base of a rhino geometry imported in revit by dynamo.
I can’t define wall or roof by mass in this type of geometry.
Do someone have a good idea the define some kind of solid elements o this surface?
Thanks a lot
@paolo.campana , hi
do you have dataformat .sat ?
afterthat you can do something like this Element.solid → Geometry.Explode →
Hi Draxl,
thanks in advance,
Do you think i have to link this node directly to import from sat node?
It seems works only on some geometry, not on all…
