Hi, I have an issue creating Solid.ByLoft. It gives an error saying
LOFT_SURFACE_SELF_INTERSECT – Loft surface self intersects. I have a list of list containing 12 points for each cross-section.
In python script node can I use any Polycurve method to exclude those polycurves which are self intersecting. Or suggest any other method or technique to remove polycurve. I tried PolyCurve.DoesIntersect(geometry) method but it is finding out intersection with other geometry.
I am getting these cross-section points from Civil 3D, and I don’t want to change the frequency of cross-section.
Here is the Dynamo script file.
Create_TrackSlab_ByLoft_Test.dyn (44.7 KB)
Any help would be appreciated.
