Solid.byloft doesn't work
Hello there,
I wish run a loft by polycurve like a first pic, but solid.byloft doesn’t work to me.
it goes in error:
‘‘Unable to loft! : BAD_WIRES – This is a bad choice of wires.’’
How can I fix to get solid?
@stemilan96 ,
did you check the order of the polycurves?
in my case i had to reorder my profiles (rectangles)
How can I reorder my polycurve?
The ‘‘sastrugi’’ node should sort points which it will be connected each other in a polycurve
@stemilan96 ,
sort by level or by ZValues… which ParameterValues have a potential to get sorted?
or you can create a Guidline and loft by that like in my screenshot
I tried that
But still It doesn’t work.
The node ‘‘solid.byloft’’ shows me error ‘‘Avviso: Solid. Operazione ByLoft non riuscita.
Unable to set the sections or the centerline! : BAD_WIRES – This is a bad choice of wires.’’
@stemilan96 ,
like this… you have to sort your points coresponding to the ZValue!
2022-07-06_16h56_22
I’ll get same result than before.
I think node sastrugi does that
It works to sort a list of points and therefore you may obtain some polycurve from this list.
In fact, If I try to get a polycurves directly from list whitout pass along sastrugi, I’ll get a disorganized polycurves and not some perimeters like in the screen before
@stemilan96 ,
when you take the shape direktly, you can use Element.Geometry to shift it to dynamo
ya but I don’t work whit a shape.
I imported a mesh from Rhino and I’m looking for building a dynamo script to transform this mesh in a solid element to export it in Revit
@stemilan96 ,
can you share the file? is it linked to a project or family inviroment?
sorry I can’t, It’s for my thesys project
which format is it? @stemilan96
.sat? .3dm? can you create a demo file?
it’s a .3dm file.
You can create a mesh in rhino a so you might export that in a .3dm file and import in dynamo by rhynamo nodes
ok, I tried to subdived polycurves two by two and I can get some little solids which I’ll join each other to get a single solid.
However, how you can see, sometimes solid.byloft doesn’t work and I’ve no idea why this happens.
Also, It happens a strange thing about solid’ surface, they don’t appear as a homogeneus surfaces.
Could you help me starting from here?
