Has anybody also noticed the Solid By Loft node skipping cross sections? Even with the guideCurves option.
Change GeometeyScaling. Similar issue was discussed here:
Hi @Kulkul, I tried that but it didn’t resolve this problem. Also, it will give me other problems because of the large coordinates I’m working on here.
@John.DeLeeuw Could you please drop here dyn file?
Here is a video showing changing Geometry Scaling doesn’t solve:
Right, so I found the solution for this non-logical behavior
I just needed to re-create the path using points based on the original Coordinate Systems and then creating a new Path from this. Somehow the conversion of the original Feature Line to a PolyCurve was bad input for the sweep. Now its looking very good!
Glad you solved it. Please mark the post as solved.
Cheers!
Hello Mr @John.DeLeeuw, I am asking for your help. I am still a beginner in dynamo. when I run a solid by sweep of more than 10 points (less than 10 points dynamo works in a normal way) the software crashes. I’d like to have your opinion. Thank you
