Ok, so I’ve got myself a real challenge here. I have an IFC file which I need to create a slab, or some kind of mass underneath it.
The IFC is all curvy and bumpy, and I need the slab to cover the whole file, but not go above it, if that made any sence. The reason being, is that I need to be able to export the created mass as an IFC, eventually create a hole/void in it, and then be able to calculate how much of that total mass the hole/void is. (For digging purposes, volume calculations).
Any idea how to solve this? I’ve tried all day with different soloutions on the internet, but I can’t really get it to work.
I’ve not saved any of the files with the things I’ve tried to work this out, but:
I’ve tried opening the IFC in Revit - Exporting it as a DWG - Importing the DWG and making it a topography surface.
After this, I’ve ran various scripts, with no success, and a lot of crashes.
I looked at your blog, and tried to do it with mine, but I couldn’t quite work it out. Does the surface HAVE to be a topography surface? Is there no possible way of creating a solid mass UNDER the curved/bumpy IFC? Does it require any special format ect?
I’m quite new to this, so I must appologize if I sound like a total noob.
I need to be able to export whatever mass I create to IFC, doesn’t matter how deep it is, as long as the top of that mass matches the imported IFC terrain.
