I am trying to take the geometry from a floor slab, create a mesh of around 0.5m and create different framing elements for the vertical, horizontal and diagonal members.
With some help, I’m now able to create the framing members using Mesh.Plane but when i try to use the face of the model element I can’t reduce the mesh size.
I have 2 questions;
- Is it possible to specify the mesh size using Mesh.ByGeometry?
- Is this method the best way to create a mesh of a slab and insert framing elements? My slab is 50m x20m
Thanks for any help!
Eamonn
2019 01 29 Mesh lines from select model object.dyn (69.4 KB)
