Hi All,
I’m relatively new to Dynamo but have used Grasshopper for a long time.
Whilst producing a feasibility study to see how many houses we could fit on a proposed site it occurred to me that there must be a way of automating it using Dynamo.
Aims:
I’d like to be able to input a site boundary and a curve to represent the centreline of the main access road, then dynamo would offset curves to make road, then subdivide the remaining areas into houses with the required spur roads to allow access.
Does this sound like a plausible project and has anyone seen anything like it already done?
Thanks for your time and suggestions.
Rich
Yna_Db
October 31, 2017, 10:29am
#2
It seems difficult at first sight since you would probably face geometric issues such as this one:
Hi there! I have a problem where I want to create a beams orthogonal to two curves where the maximum allowed space between the beams can be 2 meters. So on a straight track the spacing is 2 meters, but on sections that turns, either concave or convex, spacing should use either the outside curve or the inside curve as reference for the spacing between the beams. All the time keeping track of the already created beams. I figure this can be solved with some clever iterative Python or Designscript …
I would go for something like this: https://www.bentley.com/en/products/product-line/site-analysis-software/siteops
Maybe have a look at the Space Planning package.
richard.gwiltQ9JJS:
The task would be to express design intent using code.
Possible. Would require quite a bit of work though.
I think, utilizing Design Script/Dynamo for such tasks would help expose it’s immense potential as a design (/) automation tool.
I found this a while back, does it seem like something that could get you started?
In October, 2015 an approach I developed for space planning and programming using Dynamo was posted on the Dynamo Blog and now resides as a Use Case on the Dynamo website -- you can read about the original version in THIS BLOG POST. Since then, I...
http://dynamobim.org/space-planning-data-cycle/
Yna_Db
October 31, 2017, 4:20pm
#7
This AU class could optionally be worth a look:
Additionally:
