Hi everyone,
i’m new in Dynamo but i can intuit its potential.
i work in shoes bussines, and i’m trying to create something very common. this is a typical striped fence
i’d like to distribute some vertical lines in a surface, maybe distributing points in both curves that generate that surface, and maybe could i connect this points, two by two to create a line and afterwards a pipe in every line
i tried to recreate this but with primitives and pattern , and in some parts the objet “sinks” in the surface
could anyone help me a little?
thanks in advance!
cheers
Joseto
Is there a particular reason you’re using Dynamo? You might be better off using Grasshopper as Rhino lends itself (much much much) better to product design.
This is certainly doable.
- Select the surface.
- Get the perimeter curves (should be only two lines at the top and bottom of the surface).
- Get the longer of the two.
- Get points along its length at the desired distance.
- Get the point on the shorter of the two curves that is closest to each point on the longer curve.
- Draw an isocurve by those points on the original surface.
- Make whatever shape you want off of the resulting line.
Give it a shot and see where you get.
