GOOD AFTERNOON EVERYONE
I WANT TO KNOW IF IN DYNAMO IT IS POSSIBLE TO OBTAIN THE FACES OF A CUBE IN THE SAME DETAIL VIEW.
It sure is:
Here is an example graph, which utilizes the DynamoUnfold package from @Michael_Kirschner2:
More complex shapes can cause issues, but it does work with curved surfaces as well. More info on the package’s github page here: GitHub - mjkkirschner/DynamoUnfold: Library for building topology from sets of surfaces and unfolding them using Protogeometry tools in Dynamo
here is
an animated box with foldable-unfoldable magnetic edges, I’ll leave the script to you (you can simplify the big block code (the alphabet is almost there)
script:
cube dépliement2.dyn (30.7 KB)
Cordially
christian.stan
