I have 3 results. Out of three I want to show only one output based on the category selected.
For ex. I have Lines category, Textnote category and filled region categories. At the beginning of the script if I select lines category then it should only show the lines result as output in dynamo player. I have added one watch node at the end to view as output in dynamo player.
Can anyone please tell me how to do this ? Thanks in advance.
Hope I can use Watchdialog node from spring nodes package. Based one the category selected I can easily give it as output. I found it as a easy way. If any other solution it is really appreciated.
Hi I appreciate that but If I have 3 results or more than two results. I want to show only one as output based on the category selected.
For ex:
As I have explained in the problem statement, I have 3 categories to select and I have 3 outputs.
If I select lines category, It should only show me the lines results as output. If I select text notes then it should show me text note results. I mean I have 3 inputs to select my category and I want only one output to show them as result.
Based on the category selected the output should be shown. Please see the snip in the problem statement for your reference.
