Input or Input
Hello
I was wandering if there was a way to let the user choose by either selecting elements or all elements of a category while using dynamo player.
which means if he picks one the other input will not go through.
appreciate any help
I would use a scopeif node, so that if Select model Element is empty, the wall category gets fed into the next node.
Just now realised that if you do this, it will result in an error when its left empty|:
If you want to go the Python way:
from  Autodesk.Revit.UI import *
clr.AddReference('RevitAPI')
# Place your code below this line
if IN[0]:
	output = uidoc.Selection.PickElementsByRectangle()
	output = FilteredElementCollector(doc).OfCategoryId(UnwrapElement(IN[1]).Id).WhereElementIsNotElementType().ToElements()
OUT = output
