I am trying to print a list of all sheets with name / number / rev from a directory of files?
I know on a single file this would be really straightforward - but cant figure out how to tie a directory list into the script.
Any help would be much appreciated!!
Thanks!!
Hi @jaclyn.s ,
Yes it is possible to print sheet from files in a directory and get parameters from sheets.
But show us what you have tried.
One of the main goals of the Dynamo community is to help others. One way to do that is by answering your questions. But to get the right answer, you’ll first have to ask your question in the right way. Although people are generally very helpful, there are things you can do to improve your chances of getting good and quick answers. Below you will find some suggestions on how to achieve that. Do not think of these suggestions as rules and especially do not take them as a guarantee of getting an an…
Hi @Alban_de_Chasteigner thanks for the suggestion!
Unfortunately not all the models I am working with are linked & there are 100+ files I need to extract sheet names in use from.
I was trying the below - but this obviously only works on a file by file basis.
Would you know any way to get the content from a directory rather from links?
Thanks!
Hi @jaclyn.s ,
Did you try my previous answer ?
You can extract all the parameter values in one click if your models are all in the same directory.
Hi @Alban_de_Chasteigner I had tried with the file path solution you posted, but not with this new directory.
The new directory option works
Thanks for your help!!
