Was it my imagination (or an AutoLISP flashback), but did I see nodes somewhere for setting and getting variables to be reused within a graph? Please advise.
At this stage it only works with core input types, minus code blocks.
[quote=“Dimitar_Venkov, post:4, topic:4791, full:true”]
[/quote]Variable, but not too variable.
Is there another way to do it, like using def in a code block?
Partially. Let’s say you want to call a material or a floor type, then you can totally do that as a DS function with no inputs like so:
[quote=“Dimitar_Venkov, post:6, topic:4791”]
Partially. Let’s say you want to call a material or a floor type, then you can totally do that as a DS function with no inputs like so:[/quote]Very good. Is there a way to store a variable list to be reused in the DYN?
I’m not sure I follow you. Could you reiterate on that? Maybe post an example.
In the image I posted, the variable I wanted stored was a list of Family names that I wanted to use in many different places in the graph.
I just ended up copying/dragging the result from that Family.Name node all over the graph.
Clever but it is still static, not variable
You’re a tough customer
If you don’t mind writing to an external buffer, you can always utilize the “File.FromPath” node:
