Setting Yes/No Visibility Parameters on Sheets
Dear Users,
Apologies for what appears to be a duplicative post, but I cannot seem to find the solution to the following:
I want to simply be able to turn a visibility parameter on/off for a select group of sheets (in this instance those with a P in their Sheet name).
I have the attached the following setup, I simply cannot understand why my SetParameterValue.ByName Node cannot identify the “DRAFT” shown both in the visibility parameters of the sheet and the value I’ve put into that node? It returns “No Parameter Found by that name”.
Any help would be greatly appreciated!
Thank you in advance.
Best,
Anthony
You need to change Sheets to Title Blocks. They are different entities.
