Setting values of unaligned walls
Hi all,
I followed this post https://forum.dynamobim.com/t/using-dynamo-to-identify-non-parallel-walls/21246 about fixing the unaligned walls. I’ve fixed the values that I’d want to get but my problem is how can I update the wall angles or say the vector.xaxis with the values that i fixed?
also as an additional info, instead of using dictionary the flattening like on the posted topics. I just get the values that I want to change via python script. here’s the code:
walls = IN[0]
updated_walls = []
for wall in walls:
    if wall == 136:
        updated_walls.append(135)
    elif wall == 46:
        updated_walls.append(45)
    elif wall == 91:
        updated_walls.append(90)
        updated_walls.append(wall)
OUT = updated_walls
thanks in advance!
UnalignedWalls.dyn (26.6 KB)
here by tickling the API
class Location
Try to adopt for a wall then make a loop if it corresponds to your expectations.
import System
import math
clr.AddReference("RevitAPI")
app = uiapp.Application
elmt=UnwrapElement(IN[0])
ang_radian=IN[1]*math.pi/180
cur_loc=elmt.Location
cur=cur_loc.Curve
end_curv=cur.GetEndPoint(0)
vec_z=XYZ(end_curv.X,end_curv.Y,end_curv.Z+2)
line_axis=Line.CreateBound(end_curv,vec_z)
rot=cur_loc.Rotate(line_axis,ang_radian)
OUT = elmt,cur_loc,cur,end_curv,line_axis,rot,ang_radian
cordially
christian.stan
thanks! will try this.
just an update, found a solution. Thanks @christian.stan for the tip. I can’t quite follow what’s happening on the api but i made it as a guide to figure out with minimal python script.
so the workflow was:
1.get the angle of the element, find the direction (you would want to rotate the element on the start point as the origin);
2. whatever the angle, catch it so it would go to the nearest 45deg. on my case i made a range of 20deg (+10deg/ -10deg from whatever 45deg)
3. rotate the geometry then set the location.
dynamo script is attached for future reference.
AlignUnparalledWalls.dyn
