I am newbie to dynamo, I managed to create duplicate structural framing types from excel using dynamo. Can I set the “type parameter” of the beams width & depth using Dynamo too? here is sample of the of the beams but the real list is huge
Use SetParameterByName node after you duplicate structural framing types.
thank you, i tried that before i put the post & didn’t work, I found that i used code block for the parameter name but i forgot to put the parameter name in " " & that’s y it didn’t work with me before.
