Whenever I try to set a schedules itemize every instance property to false it removes sorting applied to the schedule. This happens with Archi-labs node and a python node I copied here. This happens if I place the node or python node before or after Archi-lab’s schedule sorting grouping node.
ProcessLists = lambda function, lists: [ProcessLists(function, item) if isinstance(item, list) else function(item) for item in lists]
ApplyFunction = lambda func, objs: ProcessLists(func, objs) if isinstance(objs, list) else [func(objs)]
def Unwrap(item):
return UnwrapElement(item)
if isinstance(IN[0], list):
schedule = ProcessLists(Unwrap, IN[0])
schedule = Unwrap(IN[0])
itemize = IN[1]
def task(schedule):
definition = schedule.Definition
result = definition
result.IsItemized = itemize
return result
OUT = ApplyFunction(task,schedule)
