Hi All
Can any one explain me how to trigger “Itemized” when creating schedule from dynamo please???
Can create schedule sort it using Archi-Lab package but cant untick Itemized
Regards
Hi All
Regards
You would have to use python.
http://www.revitapidocs.com/2016/10fc3753-29a0-8b1a-2f21-77f2634a4b9f.htm
Hi Thanks for reply
I can get value but struggling to Set it can any one help me here please
clr.AddReference(“RevitAPI”)
app = uiapp.Application
refschedule = UnwrapElement(IN[0])
gg = UnwrapElement(IN[1])
refdefinition = refschedule.Definition
lol = refdefinition
refdefinition.IsItemized(gg)
OUT = refdefinition;
IsItemized is a property so it is set with an equal sign (rather than as an argument for a method)
change the line to refdefinition.IsItemized = gg and your code should work
PS - use the </> symbol in the formatting options to paste your code here as preformatted text
Thanks you save my day
Regards
I had the same question…I’ve copied and pasted the corrected Python code above, but I’m still a little confused. What goes into the second port on the Python node?
I can create/sort my schedule, and a I just want to uncheck Itemize Every Instance. I was unsure why I would need to input 2 things into the Python node for that.
Never mind, answered my own question. Just need to provide a Boolean in the second port (set to False in my case).
Hi, I’m not very familiar with Python, can you share the node with me? thanks a lot
SCHEDULE ITEMIZE_OPTION.dyf (3.7 KB)
For the one’s still looking.
Thank you @assoffthewall
