Setting AECPSDAUTOATTACH to ON using dynamo
Hi all,
I am working on a tool that requires the use of additional property sets. I have made a graph that creates them automatically but they do not show until AECPSDAUTOATTACH has been turned to ON.
I want to make this process as automatic as possible, is there a way to turn AECPSDAUTOATTACH to ON using dynamo?
Cheers
have you tried sending the command directly to the command line ?
in case you don’t have it yet :
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
import System
from System import *
app = System.Runtime.InteropServices.Marshal.GetActiveObject("Autocad.Application")
adoc = app.ActiveDocument
adoc.SendCommand("AECPSDAUTOATTACH\nON\n")
OUT = str("AECPSDAUTOATTACH command sent")
