Hi!
Im creating an adaptive component for a facade of a mass. The component is now working perfectly and I have a facade where those elements are rotated individually based on a pattern. I’ve tried to link this to Dynamo and the script is working well, however till the last step:
setparameterbyname > it mentions the error that the parameter i want to adjust is a read-only parameter. This is half true. In the project when i go to the in-place editor by pressing “Edit Mass” to adjust this parameter (picture 1) there it allows me to adjust the rotation.
But if i go out this inplace editor mode by clicking “Finish Mass” it is indeed a ‘greyed’ parameter (picture 2)
I suspect that Dynamo only runs in a normal ‘environment’ and not in the inplace editor mode. Is there a way to bypass this? Otherwise i have to manually adjust the 1000 components haha for its rotation angle
I’ve attached the dynamo file
Dynamo - Rotatie script lamellen.dyn (22.7 KB)
Thanks in advance!
