Set value of family type parameters by name
i have created a list of type parameters in a revit family.
Like in this topic: Adding Multiple Parameters in the Family Editor
Now i try to set a list of values to the parameters.
Here is the list in the family:
and here is what i have:
But i get null with the “Family.SetParameterByName”-node from DanEDU
and i don’t know what i need to set for the element input for “Set Type Parameter”-node…
Any help would be great:)
EDIT: Im working in the family editor.
Why aren’t you using the regular Element.SetParameterByName node?
well i don’t know what i need to select for the Element input, because my parameters are only in the Family.
Right, then, indeed, it does not work. You’re right.
Considering it’s a type, maybe try to use FamilyType.ByName node here to get the right type…
But frankly I do not really know.
@erfajo, thx for helping.
Now i left the input of document empty, but there is still something wrong.
Any other idea what could be wrong?
your right!
your node needs integer and i have double
Mh, well…but if i round the doubles…the values aren’t right
oh…i forgot this
but i have still an null value:
I have my length in m and my angles in degree. The angles are realy small. Like 3°.
sure
18_03_22_Forum.dyn (19.1 KB)
18_03_22_Forum.dyn (18.3 KB)
Im sorry, i delete the “select element node”. The upload is updated.
Mh, i got the same results. With the one type parameter it works.
Yes it is ok for me to work with a dummy parameter.
But the length units are not correct…i changed the python script to
Thx you for your help!
Ah! Thx again!
