Set System Type to No Pipe Items
I have several items in Storm Drain and Sanitary systems those are not pipes, i.e. they are Chambers, Covers, etc.
For BOQ I need to assign the System Type to each element, Attached Screen and program.
On the last Node Setparameter, it fails showing error “Parameter’s Storage type is not String”
I cant understand this error, Please help resolve this.
-SamirSet System Type.dyn (9.1 KB)
Hi @samirdesh100
Try change the input into “Value” of “Element.SetParameterByname” node from “System type name” to “System type”.
Cheers
WOW!!! PARIS, you solved my problem, it worked, Appreciated.
My another finding is I cannot assign System Type to Pipe Accessories, which is right, they will absorb the system type from connected elements, some of my chambers were in Pipe accessories, I changed them to Plumbing Fixtures and it worked.
-Samir
Hi @samirdesh100
you are welcome, if your problem has been solved, can you mark the post as solved?
Solved posts can help other users, who face the same problem.
Cheers
