I want to change pipe system type in my project. But it showing some error…
warrning message:
Warning: One or more of the input types are not matching. Couldn’t find a version of Type that takes arguments of type (__array)
Thanks in advance
warrning message:
Thanks in advance
It’s showing error because you need to feed in a Element instead of a parameter value. Try connecting All Elements of Category to Element.Type
If you dont mine.can you mark that (what u replied ) in my attached file…
Thaquu I ll check and get back you😊
I want elements as per system type…can you check once…
can u give node for that…
It depends on which value you want to be .Set() to the Element.
Thank you .I ll check it
is theres a way that i can select only the element i want to change the piping system???
