Hey,
So I have a schedule (that someone else made) it has hundreds of parameters, every time I make a calculated field, it gets dropped at the end.
Rather than clicking Up for 10 minutes I tried to write a little python script.
There is an insert sort field method, but I couldn’t get it to work… I presume that it must be an ennumerate to have an order? I’m not very experienced with working with those unfortunately… I tried to ‘remove’ and ‘insert’ but they returned not supported?
https://www.revitapidocs.com/2020/8e9b2895-7627-7430-6db4-0ed0e25ffa60.htm
The other idea I had was Remove & Insert methods from the API… Unfortunately Insert requires a schedulable field, which a calculated field is not…
https://www.revitapidocs.com/2020/31528702-22e7-f515-5edc-9356585e3bc1.htm
#thanks All!
clr.AddReference('RevitAPI')
from Revit.Elements import *
clr.ImportExtensions(Revit.GeometryReferences)
schedule = UnwrapElement(IN[0])
name = IN[1]
definit = schedule.Definition
countParameters = definit.GetFieldCount()
for i in range(countParameters):
field = definit.GetField(i)
if field.ColumnHeading == name:
definit.RemoveField(field.FieldId)
definit.InsertField(field, 0)
OUT = definit.GetFieldOrder()
Re Sort Schedule Columns.dyn (18.6 KB)
Any help would be greatly appreciated…
Thanks,
Mark
Hi Mark.
I think I figured it out as I got it working in a test project I made.
#thanks All!
name = IN[1]
definit = schedule.Definition #Gets schedule definitions
field_order = definit.GetFieldOrder() #Gets schedulefieldid in current order
field_names = [definit.GetField(i).ColumnHeading for i in field_order]
ind = field_names.index(name) #Finds the index of named field
field_order_int = [v.IntegerValue for v in field_order] #Converts ordered list to ints
field_order_int.insert(0, field_order_int.pop(ind)) #Reorders so named is at 0 index
new_field_order = [ScheduleFieldId(i) for i in field_order_int]
definit.SetFieldOrder(new_field_order) #Create and set new field order
field_order = [definit.GetField(v).ColumnHeading for v in definit.GetFieldOrder()]
OUT = field_order
It was able to send the calculated field to the front. The number used as the index is set in the field_order_int.insert(0, ...)
line, where 0 is the number.
Explanation part below:
Going from your progress, I figured if there is a GetFieldOrder, maybe there is a SetFieldOrder and there was. It requires a list of ScheduleFieldIds but we get that from GetFieldOrder so I just need to reorder the GetFieldOrder. GetFieldOrder returns them as an IList so I originally tried to reorder it using the IList commands but got some weird error deep within the Revit config files so I turned it all into a python list of integers, reordered them, then turned the integers back into ScheduleFieldIds and it all worked.
Let me know how it goes.
Thank you so much!
will go stare at it for a while!
