Hello, I’ve been trying to extend the usage capablities of the Archi-Lab Custom Node to include the option to toggle Grand Totals and Itemize every instance but haven’t had any luck. I thought I could access these properties similarly to how Archi-Lab accesses Blank line/ShowHeader/Etc. But all I seem to be doing it breaking the script…
My edits are between the two ################ lines.
I’m also a bit confused by how Archi-Lab calls inputs…
Blank for example: _showBlankLine = IN[2] this is where the variable is first set but as _showBlankLine, but later it’s called inside
def createSortingField(fieldId, blank, fCount, fTitle, header, sOrder):
how did _showBlankLine become linked to blank?
Thanks for any help you can offer! Very novice “coder” but learning every day!
# Copyright(c) 2015, Konrad Sobon
# @arch_laboratory, http://archi-lab.net
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
# The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
_keySchedule = UnwrapElement(IN[0])
_paramName = IN[1]
_footerCount = IN[3]
_footerTitle = IN[4]
_header = IN[5]
_sortOrder = IN[6]
showGrandTotal = IN[7]
itemize = IN[8]
# "Start" the transaction
def getFieldId(schedule, name):
definition = schedule.Definition
count = definition.GetFieldCount()
for i in range(0, count, 1):
if definition.GetField(i).GetName() == name:
fieldId = definition.GetField(i).FieldId
return fieldId
def addSortingField(schedule, ssgf):
message = None
try:
definition.AddSortGroupField(ssgf)
except:
message = "You can add Max of 4 sorting/grouping parameters."
pass
return message
message = None
ssgf = ScheduleSortGroupField()
ssgf.FieldId = fieldId
if blank != None:
ssgf.ShowBlankLine = blank
checkList = [fCount, fTitle]
if any(item == True for item in checkList):
ssgf.ShowFooter = True
if fCount != None:
ssgf.ShowFooterCount = fCount
if fTitle != None:
ssgf.ShowFooterTitle = fTitle
ssgf.ShowFooter = False
if header != None:
ssgf.ShowHeader = header
if sOrder != None:
if sOrder == "Ascending":
sortO = ScheduleSortOrder.Ascending
ssgf.SortOrder = sortO
elif sOrder == "Descending":
sortO = ScheduleSortOrder.Descending
message = "Schedule Sort Order can only be \nset to Ascending or Descending.\nCheck your spelling please."
if message == None:
return ssgf
return message
if type(_paramName) == list:
definition = _keySchedule.Definition
if definition.GetSortGroupFieldCount() != 0:
definition.ClearSortGroupFields()
for i, j, k, l, m, n in zip(_paramName, _showBlankLine, _footerCount, _footerTitle, _header, _sortOrder):
fieldId = getFieldId(_keySchedule, i)
ssgf = createSortingField(fieldId, j, k, l, m, n)
if type(ssgf) == str:
message = addSortingField(_keySchedule, ssgf)
fieldId = getFieldId(_keySchedule, _paramName)
ssgf = createSortingField(fieldId, _showBlankLine, _footerCount, _footerTitle, _header, _sortOrder)
def createScheduleAlts(showGrandTotal, itemize)
message = None
sd = ScheduleDefinition()
if showGrandTotal != None:
sd.ShowGrandTotal = ShowGrandTotal
if itemize != None:
sd.IsItemized = IsItemized
if message == None:
return sd
return message
# "End" the transaction
# Assign your output to the OUT variable
if message == None:
OUT = 0
OUT = '\n'.join('{:^35}'.format(s) for s in message.split('\n'))
