Schedule Field Sort order(move parameter up)
in my project having around 80 schedules need to sort the schedule field data is that possible using Dynamo
hello @dhilipseshan
a solution with python
clr.AddReference('RevitAPI')
import System
def getFieldIndex(scheduleDef, paraName):
    orderedfield_Ids = scheduleDef.GetFieldOrder()
    pyListfield_Ids = list(orderedfield_Ids)
    for idx, field_Id  in enumerate(orderedfield_Ids):
        field = scheduleDef.GetField(field_Id)
        if field.GetName() == paraName:
            return idx, pyListfield_Ids
    return None, None
toDoList = lambda x : x if hasattr(x, '__iter__') else [x]
lstView = toDoList(UnwrapElement(IN[0]))
paraName = IN[1]
indexToPlace = IN[2]
for v in lstView:
    if v.ViewType == ViewType.Schedule:
        scheduleDef = v.Definition
        idx, pyListfield_Ids = getFieldIndex(scheduleDef, paraName)
        if pyListfield_Ids is not None:
            pyListfield_Ids.insert(indexToPlace, pyListfield_Ids.pop(idx))
            newOrderedfield_Ids = List[ScheduleFieldId](pyListfield_Ids)
            scheduleDef.SetFieldOrder(newOrderedfield_Ids)
OUT = newOrderedfield_Ids
Thank you so much.
you have saved a lot of time since the project contains more than 80 schedules.
this script will be very useful for big project schedules. thank you so much.
its an amazing work
