Set Phase by Name
Hi everybody,
I’m trying to set all elements in my model into the Phase Created = Phase 0 parameter.
I have some problems with the SetParameterByName node. I think this doesn’t understand this parameter like a string.
Can everybody help me please?
Thank you in advance.
Hi there,
You should have a Select Phase Node with a dropdown to select “Phase 0” or any other from your Revit document. You should use that instead of the string in the code block.
Also make sure that the parameter name matches exactly the parameter name in your Revit file.
Cheers
Like this:
I think I have not this kind of node in 0.9 version but I have a clockwork node Document.Phases.
