Hi all,
I would like to know if there is away to set a parameter value for all elements visible in a certain view.
I want to assign a text parameters ( scopebox1) to all elements in scope box ‘‘1’’.
Any idea?
Daan
June 9, 2022, 2:54pm
2
Hi @Amodio.Alessio ,
Not trying to be rude but searching for literally 1 minute gives me multiple results which answer your question, for example this one:
Running into an issue. actually a couple of issues. using two different methods to get a list of elements out of A view I get 2 different results
Option 1 Using All Elements in active view I get 655 elements in a default list
Option 2 Using Views and Collect.Elementsin View I get 675 elements and a 0 list
See image for one difference. (Element 0)
What I am trying to do is using Option 2 and get a default list not a 0 list
Thanks in advance
[Lists] test.dyn (4.8 KB)
Hi, thanks to not have been rude, but I am dynamo beginner.
This is even more accurate. I mean I can set parameter to elements that Intersect scope boxes?
Thats exactly what you see in the output @Amodio.Alessio
