Hi all,
I want to set parameter for a family, but it is not a string or number. (nested family)
Please advice?
if the child families (families and types in the drop down) are also loaded in the project.
it is possible to do what you want. check example below:
the parameter to be used is shape:
before dynamo is executed:
after dynamo is executed:
-biboy
Hi @Ali.almurshed maybe try before the get parameter value node to see the differents results and then use that like value into set parameter node.
Cheers
@paris
Can you please clarify more?
Hi @Ali.almurshed can you drop an example on revit
R19 or R20?
Cheers
