Hello all,
I cant find the package or the node for element.setname. would please tell me how to get this node from clockwork, I am on revit
@ahmad7WGJV … check out!
which revit version do you have?
2022
clr.AddReference('RevitAPI')
items = UnwrapElement(IN[0])
names = IN[1]
def SetElementName(item, name):
# family parameters
if item.GetType().ToString() == "Autodesk.Revit.DB.FamilyParameter":
try:
doc.FamilyManager.RenameParameter(item, name)
return True
except: return False
# regular revit worksets
elif item.GetType().ToString() =="Autodesk.Revit.DB.Workset":
try:
doc.GetWorksetTable().RenameWorkset(doc, item.Id, name)
return True
# archilab worksets (dynamo 1.x)
elif item.GetType().ToString() == "Archilab.Grimshaw.Elements.Workset":
try:
doc.GetWorksetTable().RenameWorkset(doc, WorksetId(item.Id), name)
return True
# archilab worksets (dynamo 2.x)
elif item.GetType().ToString() == "archilab.Revit.Elements.Workset":
try:
return True
# everything else that has a name property
try:
item.Name = name
return True
if isinstance(IN[0], list):
if isinstance(names, list): OUT = [SetElementName(x, y) for x, y in zip(items, names)]
else: OUT = [SetElementName(x, names) for x in items]
if isinstance(names, list): OUT = SetElementName(items, names[0])
else: OUT = SetElementName(items, names)
you could rebuild it
Hi @ahmad7WGJV ,
Which version of Clockwork are you using? Make sure its 2.X
