Get element workset
Hi.
I have a simple question. How to get elements workset? I use “Element.Workset” by ArchiLab, but it gives me not a name but “Autodesk.Revit.DB.Workset”.
I tried to find here the solution, found an image of somebody’s same node. There were 3 OUTs: workset, Id, Name (if I’m not wrong). Maybe it was older version… I don’t know.
What the node gave you is the Workset. If you want to get the name of the Workset, you can use the Element.Name+ node from the Clockwork package.
Thanks a lot. It was so easy :slight_smile:
