Q: Can a analytical beam “End Alignment Method” be set using dynamo?
The yellow warning reads: The parameter’s storage is not a string, Element Set Parameter By Name Failed.
Any thoughts??
Any thoughts??
Parameter value needs to be an integer corresponding to the available options (0 and 1 in this case)
Thank you very much guys!
Because I was getting 0 as the value for the parameter value, I thought Dynamo wasn’t getting the value from the analytical beam. I was expecting a description of the parameter value rather than 0,1 or 2?
Thanks again!
