Am trying to set the Start Alignment method and the End Alignment Method to Projection but am stuck what could be the issue?
Try using Integer values to change the parameter instead of Strings?
By that you mean, I use say 5 to point to Start Alignment Method?
Yes, I am not at the PC at the moment, so cant check the number of alignment options, and how numbers might correlate to what is displayed in the parameter value.
Thank you it has worked.
Great, can you mark the topic as solved and if possible, any chance you could post a quick screen snip or typed reply with the values 0-? and what they return in Revit? That would be a huge help to future searchers in the forum
