Hi everyone,
I would like to create beams with the analytical line at the center of the beam.
When I use beam by curve in Dynamo, the default setting for the position of the beam is “high”.
Any idea?
See my beams
Element.SetParameterByName maybe?
To understand you question correctly,
Do you want your beams to stay where they are now (Top level of beam) and just make your analytical line in the center? or
You want your beams Top levels to shift such that the curve inputs you have used to create are the Analytical position?
Second option ! ![]()
That’s why I’m trying to change the parameters “Justification Y” and “Justification Z” from High to Center .
I just figured that out, it works, thank you very much !
Cheers
