I am having trouble setting the Load Classification property of DemandFactorId in python.
# Enable Python support and load DesignScript library
clr.AddReference('RevitAPI')
#import Revit
from Autodesk.Revit.DB.Electrical import *
type_of_building = IN[0][0][0]
load_classification = IN[1]
demand_factors = IN[2]
parent_list = []
app_list = []
app_list.append("Old Demand Factor --> New Demand Factor")
def get_demand(name):
rtn_val = "NULL"
for demand_factor in demand_factors:
unwrap = UnwrapElement(demand_factor)
u_name = unwrap.Name
if u_name == name:
rtn_val = demand_factor
if rtn_val == "NULL":
for temp in demand_factors:
if temp.Name == "Default":
rtn_val = temp
return rtn_val
for item in load_classification:
try:
unwrapped = UnwrapElement(item)
# Get Demand Factor ID
# Load Classification ID
ele_name = unwrapped.Name
ele_demand_id = unwrapped.DemandFactorId
demand = get_demand(ele_name)
u_demand = UnwrapElement(demand)
demand_factor_id = u_demand.Id
if ele_demand_id != demand_factor_id:
WHAT TO DO NOW? Been trying lots of things, and it isn't working to set the demand factor on the load class.
except:
app_list.append("Error: " + str(ele_name))
# Place your code below this line
OUT = app_list
The reason we are attempting this is because we have a Revit template that gets built up additively. We wanted to add to the setup routines a choice to select a building type (Hospital, Hotel…) and assign the Demand Factors that change per building type.
@Mostafa_El_Ayoubi I saw that Mostafa has been first to chime in on things like this for other property trouble so I thought I’d see if he has seen this before.
