Can you set the “code set style” of a corridor with dynamo?
If I use the “documentExtensions.setstyle”, it sets the style but not the “code set style”.
I didn’t find a node for that either, but you can do it with python script.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
corridorin = IN[0]
stylename = IN[1]
def codesetstyle(corridorin,stylename):
editor = adoc.Editor
with adoc.LockDocument():
with adoc.Database as db:
#Get corridor ID
corridorId = corridorin.InternalObjectId
# Open corridor object
corridor = t.GetObject(corridorId, OpenMode.ForWrite)
#Set code set stlye
corridor.CodeSetStyleName = stylename
# Commit before end transaction
t.Commit()
OUT = codesetstyle(corridorin,stylename)
corridorcodesetstyle.DYN (6.1 KB)
Both solutions work perfectly!
Thanks Kovacsv and Shahid.
