I’m trying to create a dynamo routine that adds slope patterns on every corridor in my drawing.
So far i figured out that the the “Corridor.SlopePatterns.add” method uses two feature lines and a style id, but i can´t figure out how to find out the id of the style i want to use.
Anyone has any tips or examples on that?
thanks
Still trying this.
but i now get an TypeError: expected CorridorFeatureLine, got CorridorFeatureLine
with the code below.
Some variables are named in portuguese, sorry
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
civdoc = CivilApplication.ActiveDocument
editor = adoc.Editor
def create_corridor_Slope_Patterns(corNames,FeatLines,TaludeID):
output = []
errorReport = None
i = 0
check_out = []
Procura_feat = ""
if corNames is None or FeatLines is None:
return
if not isinstance(corNames, list):
corNames = [corNames]
if not isinstance(FeatLines, list):
FeatLines = [FeatLines]
global adoc
global civdoc
global editor
with adoc.LockDocument():
with adoc.Database as db:
bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
for corName in corNames:
# Get corridor from corridor collection
corId = civdoc.CorridorCollection[corName]
cor = t.GetObject(corId, OpenMode.ForWrite)
Features_Fil = FeatLines[i]
Features_Cor = Features_Fil[0]
check_out.append(corName)
for Feat_Line in Features_Cor:
# Check if feature line is the last one
#check_out = dir(Feat_Line)
#check_out.append(Feat_Line)
Teste_nome = Feat_Line.Code[-4:]
if Teste_nome[:2] == "33":
Procura_feat = ""
if Feat_Line.Code[:5] == "Aterr":
Feat_Sl_2 = Feat_Line
Feat_Number = str(int(Feat_Sl_2.Code[-1]) - 1)
Procura_feat = "AterroBanEsq-" + Feat_Number
for Feat_Line_2 in Features_Cor:
if Feat_Line_2.Code == Procura_feat:
Feat_Sl_1 = Feat_Line_2
if Feat_Line.Code[:5] == "Corte":
Feat_Number = str(int(Feat_Sl_1.Code[-1]) - 1)
Procura_feat = "CorteBanEsq-" + Feat_Number
Feat_Sl_2 = Feat_Line_2
#Create the slope Pattern
#check_out = dir(cor)
#check_out = dir(cor.SlopePatterns)
#check_out.append(Feat_Sl_1)
#check_out.append(Feat_Sl_2)
#check_out.append(TaludeID)
cor.SlopePatterns.__add__(Feat_Sl_1, Feat_Sl_2, TaludeID)
#Next Corridor
i =+ 1
t.Commit()
if errorReport == None:
return check_out
return errorReport
OUT = create_corridor_Slope_Patterns(IN[0],IN[1],IN[2])
@henrique.foster Hello, did you solve your problem?
if not
Please share a example dyn file
until I try
Yeah, i finally got it.
the problem is that i was using the corridor feature lines a i got from a dynamo block and the python script was expecting a corridor feature line selected from the block table record.
once i managed to do that the error disapeared.
@henrique.foster could you share the workflow you are using for this script?
I am unsure how you the features line inputs are being read in the script.
