Is it possible to modify the text style through Dynamo?? I’m trying to get the text property but I’m always getting “Empty List” .
Hi @frodriguezmXYFSS
Is this what you’re trying to do?
Awesome @Kulkul
Where can I check those python scripts?
I remember seeing something looks similar before on this forum, but I cannot get it now.
Hi, can you share the python scripts to make the text style changes please. i am not too familiar with python.
This isn’t quite the same as what @Kulkul did, but give it a try. Provide a string input for the name of the text style you want to change to and it will change all Text and MText in model space.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
from Autodesk.AutoCAD.GraphicsInterface import TextStyle
editor = adoc.Editor
errorReport = None
def set_all_texts_style(style):
global adoc
output = []
with adoc.LockDocument():
with adoc.Database as db:
bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
text_styles = t.GetObject(db.TextStyleTableId, OpenMode.ForRead)
try:
if text_styles.Has(style):
for oid in btr:
obj = t.GetObject(oid, OpenMode.ForWrite)
if isinstance(obj, (DBText, MText)):
obj.TextStyleId = text_styles[style]
output.append(obj)
elif not style:
return "No input"
return 'The text style "{}" does not exist.'.format(style)
except:
import traceback
errorReport == traceback.format_exc()
t.Commit()
if errorReport == None:
return output
return errorReport
OUT = set_all_texts_style(IN[0])
Adapted and modified slightly from @Paolo_Emilio_Serra1’s original script here:
Are the text objects on a locked layer?
the layers are all unlock
@cesar5688433 Could you share here dummy dwg file?
Hi Drbohlav,
I’ve found that setting the text style that you want in Annotate tab before you run Dynamo works the best for text you are creating in Dynamo. The text created in Dynamo uses the style that’s set.
Since my Python skills are pretty much non-existent, I’ve tried setting the text style using some Dynamo gymnastics using the ObjectExtensions.GetParameters node and the ObjectExtensions.SetParameterByName node in the Civil3D Toolkit but haven’t had any success. I’d give that a try as well. Maybe I’m doing something wrong and you’ll have better results but it seems like the Python route of setting text styles may be the only option at least for now.
You guys know how to change a modified text (modified with the string replace command) in revit into a one line text?
