Set Alignment Start Station
Hi
I am working on a simple program to create alignments from polylines, and am wondering if there are any nodes available to set the start station of an alignment. The current Civil3DToolkit node “CreateAlignmentByPolyline” does not allow for setting the alignment start station. Rather than start at station 0+00 I would prefer something like 10+00. Thanks.
@hestingjj the API doesn’t allow setting the start station when creating the Alignment, but you can set it afterwards with the ReferencePointStation property.
clr.AddReference('AcMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
def set_alignment_start_station(alignment, station):
	editor = adoc.Editor
	with adoc.LockDocument():
		with adoc.Database as db:
				aeccAlignment = alignment.InternalDBObject
				aeccAlignment.ReferencePointStation = station
				t.Commit()
				pass
	return alignment
OUT = set_alignment_start_station(IN[0], IN[1])
Very cool, I got it to work for one alignment, just had to make sure it was a “number” type for stationing. Can I feed it alignment list and station list? I tried but not getting it to work. Thanks for sharing!
@hestingjj there is a node for this starting in Camber v4.1.3.
