Using Select Model Elements, I attempted to select the elements using the control key, but the only way I was able to select multiple elements was by using a fence selection. Is this only method?
What you could try is preselect the elements in Revit with the control key and then use the “isolate element” option in Revit. Then you could easily use the select model elements on everything.
Hello Nelson Weeks,
with current implementation you can select multiple elements using fence selection.
I will log internal tracking issue for improvements to support ctrl selection.
Thanks,
Ritesh
Thanks Ritesh. I actually had used the method suggested by Dimitar prior to posting and do think it is a reasonable work around. I just asked the question because it seems like ctrl is more discoverable/universal.
