Reverse engineered select model elements node
Hi all,
I was wondering is there a way to select model elements in revit based on a list of element I.Ds? Just simply feed a list of element I.Ds in a node then it selects all the associated elements in the model.
Thanks in advance
@James_Washbourne yes it’s possible.
What have tried so far?
@James_Washbourne - check out the Select.ByElementId node in the archilab package.
Jacob,
I’ve tried this node but its not selecting the items in the model. It’s giving the list, but I want to actually select the beams in the model itself.
Regards
Can you post some image of what your are trying to do or your dyn?
@James_Washbourne - You want to have the elements selected directly in Revit so you can manually perform an operation on them?
Exactly that Jacob
Thank you
