Hello friends. I want select a special fitting for example a 45 degree elbow (not 90 degree). Is it possible do it with dynamo? If yes how?
How to get help on the Dynamo forums - FAQ - Dynamo (dynamobim.com)
What have you tried so far?
When i select them with same angle i can change the type without error
Great. So now you need to define that same logic in Dynamo. Select all fittings, filter by type if necessary, and then check for angles and filter the 45s.
Thanks. How can i filter them in dynamo?can you help me?
You need to make some effort on your own first. This is not a forum for asking people to do your work for you. Work your way through the Dynamo Primer and check out some of the other threads here to get an idea of how to get elements by category and do some basic parameter manipulation and filtering.
