Select Elements in REVIT by the IDs
I’m a beginner with Dynamo and I have a selection problem.
I readed a script which select all ID element of elbow 45°. After that I would like to Select all these elbows in my REVIT Workspace to display and change a loss pressure parameter.
I tried to change directly this parameter in dynamo but loss pressure parameter can’t be change easily.
I also tried to use CAAD_RWTH nodes and it doesn’t work.
I’m on REVIT 2016 and Dynamo 1.1.0.0
Here my script
and here the result that I would like. (On this screenshot i selected manually all the elbow)
Thanks to your help
you can use this:
the select in Revit is from springs
Thank you ! This method works very well and very easily !
Hello
Do you or any other kind fellow know where this node went (“Springs.SelectInRevit”)? WOuld very much appreciate having it or any equivalent in my toolbox.
# Import RevitAPI
clr.AddReference('RevitAPI')
# Import ToProtoType, ToRevitType geometry conversion extension methods
# Import DSCore nodes in Dynamo
clr.AddReference('DSCoreNodes')
import DSCore
from DSCore import *
# Import python library
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import os
import shutil
import math
# Import math library
from math import *
#Import Data and Time
from datetime import datetime
now = datetime.now()
#Import System Library
import System
from System.IO import Directory, Path
app = uiapp.Application
uidoc = DocumentManager.Instance.CurrentUIDocument
element = UnwrapElement(IN[0])
ids = List[ElementId]()
for ele in element:
	ids.Add(ele.Id)
#Final output
OUT = uidoc.Selection.SetElementIds(ids)
Believe this code can work with what you want
