I want to be able to select Revisions by pick using DataShapes and select multiple “Packages” or SheetSets and apply that revision to those sets.
I have this graph as attached but it’s not working.
Test_Rev_Packages.dyn (30.8 KB)
TEST_RevisionToSheets.dyn (33.8 KB)
here is my latest attempt but still not working…
can somebody take a look please?
I managed to make it to work already…thanks!
How’d you end up making it work? I’m encountering a similar issue and it seems to be when I go from the selected revision in Data Shapes (in your case from the String.ToNumber node) to the Add Revisions to Sheet node. If I can convert that user selection to an element ID, it should work.
Thanks in advance!
Thanks for the quick reply! It seemed to do the trick!
can you share your code?
your screenshot is barely readable.
