Hi, sorry for my question but i couldn’t find. Is any dynamo node able to pick linked element? Like “select element/elements” in model?
Thank you i know this way but it is problem to filter the right element.
@Alban_de_Chasteigner Rhythm nodes is what i need! Simple for new dynamo users ![]()
hey, i can’t find this node on rhythm packages is is version problem ?
hello
same for me i can’t find the “select element from link” in the package.
did you found a solution?
hello again
i found the solution it’s about the version of the package
this is the version that contain the node you need
I installed rythm 2022 version and it works
Hi. I have no idea how to use it from the beginning. I want to try using it well. “Select Linked Element”
