How do I run a node that selects linked model elements?
I’m studying Dynamo, which selects linked elements. It’s still not enough, but I don’t know the “refresh” input value and I can’t handle Python code, but I’m posting this because I’m really curious. When I connect the package “GeniusLoci” node like this and click on the element in the Revit link model, it doesn’t work. What’s the problem?
seems you dont have select anything…remember hit finish in left corner after select, in revit ui, and insert a boolean in refresh so you can select again in another run
have you tried these bimorph nodes?
Thank you for your reply.
But Sorry…
I tried making a selection, but there was no response. The Revit UI doesn’t work because there is no active content in the left corner.
There is a package, but when I tried it, it required more nodes to be added.
from Rhythm package
Thank you for your reply. I found a good way to achieve results. Is there a way to run the node in my opinion?
Yeah should be there…which revit version are you in ? if 23-24 be sure you have installed dynamoironpyhon package 2.7 version 2.5 as well
Revit_DH6VuIMCDj
Oh thank you. I installed “dynamoironpyhon package 2.7 version” and it worked in Revit 2025. This time I learned about Dynamoironpython.
