THANK YOU @keith.sowinski
Really nice, Keith!
Changing the TypedValue with an IN[0] value instead “POLYLINE” you can use the Dynamo Objects Types Node as an input.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AutoCADNodes')
from System import Array
# Import references from Dynamo
from Autodesk.AutoCAD.DynamoNodes import SelectionByQuery
ed = adoc.Editor
def select_objects():
global adoc
global ed
outputQ = []
with adoc.LockDocument():
with adoc.Database as db:
#acSSPrompt = ed.GetSelection()
tv = TypedValue(0, IN[0])
tva = Array[TypedValue]([tv])
selFltr = SelectionFilter(tva)
acSSPrompt = ed.GetSelection(selFltr)
if acSSPrompt.Status == PromptStatus.OK:
acSSet = acSSPrompt.Value
hndl = []
for s in acSSet:
if s:
obj = t.GetObject(s.ObjectId, OpenMode.ForRead)
hndl.append(str(obj.Handle))
t.Commit()
for h in hndl:
outputQ.append(SelectionByQuery.GetObjectByObjectHandle(h))
return outputQ
OUT = select_objects()
#if IN[0] == True:
#OUT = select_objects()
#else:
#OUT = "nothing"
By the way, the Null result is from an AutoCAD 2D Polyline (Spline). The PolylineExtensions.GetGeometry node can only handle SimplePoly Spline types.
Any thoughts how to change the Polyline Spline Cubic into SimplePoly?
